can i turn off the ses light?
Old May 8, 2009 | 03:02 PM
2000blkz28's Avatar
Default can i turn off the ses light?
if i have long tube headers with no cats is there a way to turn off the ses or does it just stay on?
Old May 8, 2009 | 03:44 PM
whammer3024's Avatar
ROTM Winner
stays on...you can have your computer tuned to get rid of the light
Old May 8, 2009 | 04:16 PM
2000blkz28's Avatar
but wont it just turn on again once it resets
Old May 9, 2009 | 01:41 AM
95slvrZ28's Avatar
It's not going to turn off unless you install some O2 sims or do the cheap O2 mod to trick them. You can also get it tuned out, but that's the expensive way to get it off.
Old May 9, 2009 | 02:37 PM
2000blkz28's Avatar
so how would i trick them?
Old May 9, 2009 | 02:50 PM
95slvrZ28's Avatar
If you still have bungs you can put them in you can get some spark plug nonfoulers and screw those in the actual bung in the exhaust pipe and then screw the O2 sensor into that. If you're handy with a soldering iron and have bungs you can put them in you can install a series resistor and a parallel capacitor to drop the voltage output and trick the computer that way. If you don't have bungs you can buy actual O2 sims or get some bungs welded in.
fastbenni78
Aug 28, 2013 05:04 PM
Patrick Quentin Musick
Apr 13, 2013 06:56 AM
80Mike
Sep 25, 2008 04:05 PM
Andrew*B
Jun 27, 2008 11:35 AM
bill12690
May 30, 2007 12:57 PM
