back up light and turn signal
Old Mar 19, 2013 | 08:49 PM
Patrick Quentin Musick's Avatar
Default back up light and turn signal
ok i think i have moisture in my tail light houseing my question is do the rear n front turn signal bulb flash indepently my rear turn signal is out n my front on the same side is staying steady no flashing my car is 94 camaro
Old Mar 19, 2013 | 09:55 PM
Randy Bilyea's Avatar
Replace the bulb, and the circuit will have enough resistance to trigger the flasher relay again.
The OEM relay is mechanical and requires a certain load to trigger it.
New bulb = flashy-flashy.
Old Mar 19, 2013 | 10:29 PM
thank u thats the response i was looking for
Old Mar 19, 2013 | 11:06 PM
hooknladder's Avatar
Are your tail lights collecting water like an aquarium? If they are, drill some small holes in the bottom. I did this to mine and eliminated lots of corrosion issues. I also use dielectric grease in my sockets.
Old Mar 29, 2013 | 08:31 AM
TheArtfulLodger's Avatar
I had to do the same thing as hooknladder with one of my Camaros. The tail light kept collecting water and frying the bulbs. A small hole in the bottom of the tail light did the trick, though.
Old Apr 13, 2013 | 06:56 AM
FBodyjunkie's Avatar
I reglued the assembly to make it air tight again.
71ProStreet
Sep 1, 2008 12:31 PM
Andrew*B
Jun 27, 2008 11:35 AM
rollnw24inkmc
Jun 10, 2007 04:27 PM
bill12690
May 30, 2007 12:57 PM
ahlers
27
Oct 21, 2006 03:32 AM
