camaro leaking coolant.... pictures
LOL! I hear ya! I remember removing a water pump from a 82 or 83 Olds 88. That was a royal pain and an all day job! Back then, my tool box basically was an adjustable wrench and hammer!
Well got it done. I used water pump sealant, it said it is made specifically for water pump gaskets and is water resistant....
If I didn't have to go to the parts store to get the sealant it would of been a 1 hr job. There is just so much room in the front of the engine bay on the 3.8's that it is easy as pie.
Crabby, What plastic elbow are you referring too ? I already have everything put back together but I can always go back and look.
Also, thanks for the help everyone.
There is a plastic elbow that is very well hidden under the intake manifold. It runs from under the neck of the intake manifold to the belt tensioner. Unless you have a mirror, it is about impossible to see from the top. You could probably see it from underneath the car though. They have a habit of cracking, and leaking. It can almost make it look like you have a water pump leak.
