Leaking Coolant
Old Mar 29, 2007 | 07:14 PM
1977Camaro350's Avatar
Default Leaking Coolant
I have 1972 350 that leaks coolant into the case because theres a spot on the block surface where the head sits that got nicked with a grinder. Its maybe a 1/16 of an inch from one of the cylinders. Any way to fix this?
Old Mar 31, 2007 | 10:48 AM
machineman's Avatar
Default RE: Leaking Coolant
ORIGINAL: 1977Camaro350
Is that 1/16" deep? If so, I would fill it in with epoxy or weld it and then have the block decked after that. Where exactly is the nick? Can you put up a picture of it?
Old Apr 7, 2007 | 01:10 AM
sorry no pictures i would take me 2 days to get them. 1/16 of and inch is how far it is from one of the cylinders. It is not very deep cause it was just nicked with a grinder.
Old Jul 10, 2007 | 10:13 PM
Markus7711's Avatar
I would replace the headgaskets with graphite ones- they tend to shape better to imperfections. You could try some epoxy on the spot too, but not too much.
C422
Oct 22, 2013 07:12 PM
lemontime
Feb 20, 2012 08:14 PM
Yooper Z28
Nov 26, 2011 12:10 AM
Exterminex
Aug 25, 2009 12:40 AM
peter
Dec 28, 2007 10:19 PM
