Camaro Coolant Leak????
Old 04-30-2017, 03:01 PM
CamBigCat's Avatar
Originally Posted by craby
not sure what it is, doesnt look like its stock. looks like someone removed something and capped it off with a rubber fitting. can you get a better recording or still photo's to show its location better. there is a coolant level sensor in that location, also the overflow is there but its close to the radiator cap. this looks like you may have a lt1 radiator that uses a return that goes to that area and capped it off. try a new rubber cap.
With all due respect, a trusty mechanic of mine, said a rubber cap will crack, you're better off buying a metal one. I had a coolant prob., there are too many reasons accounting for a coolant leak, one of them is a cracked rubber rad. cap. The problem with mine, after numerous visits, was a coolant leak by the timing chain cover, many hours of labor intense work. Good luck Original poster.
  #152
Old 04-30-2017, 03:07 PM
he sold it
  #153
Old 04-30-2017, 06:03 PM
Y2K's Avatar
Y2K
Y2K is offline
he sold it
Well that's an easy fix.
CityGirlAlways
03-01-2017 01:15 PM
josh95camaro
02-14-2011 12:41 PM
Quick Reply: Camaro Coolant Leak????
