Camaro Coolant Leak????
#91
Again thanks!
#92
This is starting to look more like an failed intake gasket. Check you oil make sure there is not coolant in there. If there is it will look like a brown milkshake.
#93
Ohhh boy that doesn't sound too good I checked the oil dipstick and the color of it is brownish-blackish and smells like gasoline
#96
if your getting coolant at the top of the engine then i would agree with gorn, i would say most likely the intake gasket and would explain the coolant at the rear going onto exhaust.
#97
Hmm if it is the intake gasket would it drip down to the bolt under the oil filter and the k member as in the video
