A/C evap & heater core seals
Old Oct 17, 2019 | 03:33 PM
vipe155's Avatar
Default A/C evap & heater core seals
Hi everyone,
I'm rebuilding my A/C system with all new parts after a compressor failure, and while getting to the evaporator (and needing to remove the heater core), I decided to just replace the heater core as well. Only issue so far is that the evaporator and heater core pipes both have a gasket or seal. The evaporator gasket (GM 52458972) is in bad shape and partially split. New part didn't come with one, and the GM part seems to be discontinued. The heater core pipe seal (GM 52458961) hasn't faired much better.
The GM manual says to replace the evap gasket. What should I do here if I'm finding nothing to replace these seals with?
byrdman
Sep 17, 2011 05:43 PM
albo1989
Jul 26, 2010 05:16 PM
frostlime69
Mar 31, 2008 10:39 AM
95Z28pit
Sep 18, 2007 07:01 PM
mike86rs
Mar 13, 2006 11:29 PM
