Buying a 99 z28 what to look for??
Old Feb 10, 2012 | 11:15 AM
streetsteve's Avatar
Default Buying a 99 z28 what to look for??
Hey everyone new to the camaro, found a little used car dealer with a silver 99 z28 its an automatic and has 126,000 miles on it, anything to look for and watch out for, hes asking 5999 for it. Never had a car with that many miles but it looks really clean, any info will be much appreciated, thanks
Old Feb 10, 2012 | 03:45 PM
Failed Devices's Avatar
Gotta search, I swear I just answered this same question last week....
10 bolt, 10 bolt, 10 bolt. I don't know how many times I have said it, but obviously not enough. They are POS rear ends. Listen for high pitched whine and loud clunking; do note that these rear ends re noisy any way, just listen for the extreme. Seeing as the car is an A4, the rear end can take a bit more abuse, but it can still blow all too easily.
The LS1 is reliable and strong, with the only real common issue being piston slap, which is almost expected.
The 4L60E is stout for what the LS1 puts out. If you plan on H/C in the future, a rebuild will more than likely be required.
Exterior wise, look for paint bubble on the sail panel. This is a common area on fbodies for paint to bubble as the adhesive used on the fiberglass was really no good.
The price seems a bit high, but fair nonetheless. A 2001-02 would be more preferable as there were some good changes made (such as LS6 intake and no EGR). What other options does this Z have? Monsoon stereo, power access, leather, t-tops?
Old Feb 10, 2012 | 05:02 PM
Cloth seats but it does have the t-tops, looks like something is leaking out of the front emblem, almost like the adhesive melted and dribbled down the front, wouldt rub off either, ill try to post the craigslist link, cash price is 4999 bucks if you finance it it's 5999
Old Feb 10, 2012 | 05:04 PM
Old Feb 10, 2012 | 05:17 PM
FosterW's Avatar
I wish LS1's were that cheap around here.
Old Feb 10, 2012 | 05:20 PM
That seems fair for it if everything checks out. Get a carfax or something for it and have a mechanic give it a lookover and it should be good.
Old Feb 10, 2012 | 06:06 PM
Would have done the carfax but its 35 bucks for 1 car check, also teres another car for sale but a little outta my price range right now
2002 Chevrolet Camaro T-Tops
I guess it come down to i have never owned a car with that many miles, dont want to constantly have to fix things on it, also how are the t-tops are they notorious for leaking, looks like it has a small oil drip under it from the motor, oil pan looks wet, rear end looks nice and dry
Old Feb 10, 2012 | 08:11 PM
boone's Avatar
Have the dealer provide you with the Carfax. No need for you to spend your money on it. I recently purchased a '99 and I have not found any glaring issues but it is not a daily driver. I can't comment on what shape your t-tops will be in since the climate out in AZ is so much different than what we get here in VA.
Old Feb 10, 2012 | 09:07 PM
I asked if he had one and they said they dont do them there, kinda fishy if you ask me,
PSIguy
LS Series Tech
Jun 11, 2010 11:16 AM
Wilsonation
Apr 6, 2010 07:57 AM
j93mustang13
Nov 20, 2009 09:46 PM
TuftsAuto
Jan 9, 2007 04:37 PM
