Bright lights
Hey -
My brights switch is not working, or clicking when pulled back. The left and right turn signal work fine.
The bright switch was working fine also until a few days ago. Any clue what's up with that?
mine does the same thing. i just take my palm and hit the switch back pretty hard to gett the brights to come on and i do the same to go back to dim....you may need to get a new switch if that doesnt work
I discovered that this only happens on mine when I have the steering wheel all the way down. If I let the wheel up just a inch or so, no problem. Seems to be some type of plastic cover on the back of the turn signal/bright switch that the wheel kicks backwards when lowered. All is whell as long as that is not kicked out, or the steering wheel is not lowered all the way.
volcomskate1313
May 8, 2006 07:05 PM
