Bright lights
Hey -
My brights switch is not working, or clicking when pulled back. The left and right turn signal work fine. The bright switch was working fine also until a few days ago. Any clue what's up with that? |
RE: Bright lights
mine does the same thing. i just take my palm and hit the switch back pretty hard to gett the brights to come on and i do the same to go back to dim....you may need to get a new switch if that doesnt work
RE: Bright lights
You broke the switch. Change it.
RE: Bright lights
I discovered that this only happens on mine when I have the steering wheel all the way down. If I let the wheel up just a inch or so, no problem. Seems to be some type of plastic cover on the back of the turn signal/bright switch that the wheel kicks backwards when lowered. All is whell as long as that is not kicked out, or the steering wheel is not lowered all the way.
