Brake ???
Old Apr 5, 2009 | 03:20 PM
myohann's Avatar
Default Brake ???
Can anyone tell me what happens when a brake master cylinder goes out ?
How do the brakes act , are there any brakes at all.
I have a 94 v6 and the brake light is on now I just put new pads in and the fluid is full but the light is still on.
Any help would be great.
Old Apr 5, 2009 | 04:41 PM
usually thats a indication u r losing fluid on the front or rear brakes. or the e brake is on. theres a sensor that reacts to the fluid going more to the front or back and not evenly. if you bleed one or the other (f or b) too much it will also cause the brake light to come on.
Old Apr 5, 2009 | 07:57 PM
camaro_burns_all's Avatar
VIP member
when you press the brake pedal, the master cylinder is what pushes fluid to the wheels. if that is going out, then you might be heading for a brake fail
Old Apr 5, 2009 | 09:01 PM
Your story is a little vague. Were you having this problem before you replaced the pads? Or did it start after the new pads were put on?
Old Apr 5, 2009 | 11:18 PM
greenarrow's Avatar
September 2009 ROTM
Check the car for a brake light out, that will set the light off also. And from what I've always seen, usually these car spit fluid out the master when they are going.
Smittys_z28
Dec 24, 2014 02:14 PM
Willie Anderson
Dec 22, 2012 10:23 AM
XxCaMeLxxToSiSxX
Dec 8, 2010 11:27 PM
jp 71 camaro
Nov 7, 2010 08:36 PM
tyler2497
Mar 10, 2007 03:35 AM
