BLINKER LIGHT
Old Aug 9, 2008 | 05:39 PM
MidnightLS1's Avatar
Default BLINKER LIGHT
When i put on myright blinker, the arrow just sits still and doesnt move as does the actual turn signal itself. The left blinker works just fine but i cant seem to figure out how to get the right one to blink instead of just sitting still. Its a 2002 Camaro LS1, any suggestions??
Old Aug 9, 2008 | 05:59 PM
The Banks's Avatar
Default RE: BLINKER LIGHT
Usually when the blinker indicator stays solid it means one of your turn signal bulbs in the front or rear on that side are burned out.
Old Aug 9, 2008 | 06:23 PM
Even when the light itself stays on, it just wont blink, does that still mean that its burnt out?
Old Aug 9, 2008 | 07:35 PM
The Banks's Avatar
If one of your outside turn signal lights (front/back) stays solid then you might want to check the other end to see if that light is lit up. If not, burnt out light; if so, then its something else.
Old Aug 9, 2008 | 09:17 PM
randopium's Avatar
yep that means either the front or the rear bulb burnt out...just happened to me two weeks ago...
Old Aug 9, 2008 | 10:06 PM
th3po1son's Avatar
thats really odd, ive never seen a car do that
ive only seen the blinking fast deal.
Old Aug 9, 2008 | 10:35 PM
98ss4REAL's Avatar
in the front you have two bulbs a runner light and a blinker light most likely ur blinker went out and your runner lights up.
Old Aug 11, 2008 | 06:10 PM
noz's Avatar
noz
i thinkit would blink rapidly ifone of the bulbs werout...
Old Aug 12, 2008 | 01:37 AM
95slvrZ28's Avatar
The lights are set up in series rather than in parallel. Since they are on a series circuit when one bulb goes out the circuit is no longer complete and thus the car cannot complete the relay circuit that causes the blinking. Most cars are wired in parallel, so when one bulb goes out the current draw on the circuit is less and thus the relay circuit actuates more rapidly.
Kalika
Mar 13, 2010 10:59 PM
Blue79Camaro
Aug 17, 2009 09:26 PM
dletner
Sep 21, 2008 06:23 PM
94z28chevy
Jun 14, 2008 02:45 PM
LOU97RS
Apr 2, 2007 10:48 AM
