Battery Issue!
Battery Issue!
Last month I had Walmart install a new battery while out of town..
Arriving for the holidays, I see my aftermarket Pioneer radio/cd system won't even turn on.
After testing the battery and engine/side panel fuses, I'm left to wonder if it's the fuse behind the radio or a manufacturer code.
Please help with any advice or similar experience and solution you have found.
Thanks all!!!
Thanks all!!!
check and make sure they didnt unhook it at the battery when they installed the new battery. dont know how its hooked to power, or if you did it yourself, some shops will automaticly run wire to battery. other than that get the volt meter out and see if stereo is getting power.
libertyforall1776
02-24-2014 02:11 PM
The_Bandit
10-21-2011 11:46 AM
shiggy
10-14-2005 01:52 AM
