Bad Slave Cylinder?
Ok so I was cruising last night with a few people in the car. I went to go from 1st to 2nd and I couldn't get my car to come out of 1st gear. Even with the clutch all the way to the floor it didn't want to come out of gear. I pulled over and shut the car off and it came right out of gear. I started it in neutral and it wouldn't go into any gear. I forced it into 2nd while the clutch was in and it grind' a little. So I had it towed home. Now I'm stuck. I don't now why this would be happening. Seems as though my clutch isn't fully disengaging the gears. It's always been a little hard to get it into gear sometimes unless I pump the clutch a couple times. I'm leaning toward the slave cylinder here because the master cylinder has been replaced, it has a brand new clutch kit in it, and the tranny is fairly new too. Any thoughts? Anyone have a better idea? Thanks in advance!!!
That's not a clutch problem. You can shift your gears from 1-5 without a clutch. Sounds like something in your tranny isn't lined up right. Can you start your car in first with the clutch in? Good test to see if your clutch works.
I started it yesterday in 1st gear and it seemed to be okay. The car doesn't move when I have it pushed all the way down and the car moves regularly as I let out the clutch. But once again, I can't get it in or out of any gear. Also my pedal is super sticky and spongy. It's always been like that though. That's why I thought it might be my hydraulic system. It's always had a hesitance to go into gear since I bought the car. It's just really bad now. Also the fluid is good and the clutch has been bled as of about two weeks ago.
Here is a video of the movement that my slave cylinder is producing. I was told that it should move alot more than this.
YouTube - 1994 Camaor v6 5-speed Clutch Slave Cylinder
