Bad idle can you help please!!
probly just something on the exhaust manifold. check for anything leaking and anything against the manifold. if ok drive it to the store and get a soda and check after. if its still smoking then look again for leaks.
ive been hearing about inductive crossfire what is that? i couldnt get a few of the clips from the factory back on the wire because they broke will that have anything to do with it? after i made dure evcerything was tight and re checked to see if they were plugged into the right spot and everything checked out.
if there new wires should not have cross fire. pick up some looms at the parts store if u want. yah if nothin on the exhaust manifold run it for a bit and see if it clears up.
ok did that and stopped smoking. only problem is car runs same as it did before so it wasnt the wires. took it over to a friend of mine who has a scanner and a code came up for the air pump. would that have anything to do with how it idles when in gear like i discribed or no? i dont know anything about them. thanks again
