ASR Issue gone!!!
Old Nov 9, 2009 | 06:06 PM
Eureka's Avatar
Default ASR Issue gone!!!
Dont mean to sound like a newb but, I was going crazy looking for fuses, relays or what ever else that would make that ASR dash light go off. Yesterday all I did was change my break pads cause I felt they were going low. Now everything is fine!!! Now the ASR button is in control and the "ABS INOP" light on the dash is gone!!
Old Nov 9, 2009 | 07:50 PM
good deal and thats good to know, thanks for letting us in on it. whats next?
Old Nov 9, 2009 | 10:55 PM
Eureka's Avatar
Coolant is leaking when I shut the car off. While I was under the car I found that it was coming from the little hole from the bottom of the water pump. I guess that this is where it releases from when too much pressure builds (protects from cracking the radiator). Time for a water pump. Also saw the transmission line had some fluid dripping (this may cause slipage) It'll give me something to do this weekend. Just treating it with some TLC for now!!!
Old Nov 10, 2009 | 12:48 AM
thats a weep hole on the water pump. means the seal is bad and its time for a new pump. hopefully the water wont waste the opti. they dont like water. when u change the pump take the cap off the opti and see if theres any sign of water at all. check you plug wires while your down there to. best time to change them too. get that water pump outa the way and ull see what i mean.
Old Nov 10, 2009 | 05:47 AM
Eureka's Avatar
Thumbs up
Thanks Brotha!!
blazelt1
Dec 16, 2009 01:02 AM
aaron_Z28
Dec 12, 2009 08:32 PM
sbono
Apr 5, 2009 12:56 AM
Str3tch
Nov 7, 2007 02:09 PM
