Another P1406 -Question
Old Aug 15, 2011 | 06:40 PM
Massey's Avatar
215 with the AC on or in traffic is no biggy. mixing the 50/50 stuff is fine so long as you didnt add any dex cool with normal green.
The EGR should not click loud enough for you to hear, or when the car is idling. You may hear the purge valve but that should only be every now and then not all the time. If you have an exhaust leak at the EGR that will sound like a tick tick as well.
Massey
Old Aug 16, 2011 | 12:58 AM
ChevyManCam's Avatar
yeah my cooling fans are on all the time i even have both running full speed and it still hits over 210 and doesnt start going down till i start to drive for a mile without stopping i know i have a serious cooling problem though i do not have a blown head no smoke or any signs so i just think i have to bleeed the hell out of it
Old Aug 16, 2011 | 10:53 AM
libertyforall1776's Avatar
Document ID# 49002
1997 Chevrolet/Geo Camaro
DTC P1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance
Circuit Description
The PCM monitors the EGR valve pintle position input to ensure that the valve responds properly to commands from the PCM and to detect a malfunction if the pintle position sensor and control circuits are open or shorted. If the PCM detects a pintle position signal voltage outside the normal range of the pintle position sensor, or a signal voltage that is not within a tolerance considered acceptable for proper EGR system operation, the PCM will set DTC P1406.
Conditions for Setting the DTC
EGR Feedback is less than 0.14 volt at any time.
OR
EGR Feedback is 0.4 volt greater or less than the EGR Closed Valve Pintle Position when the Desired EGR Pos is commanded to 0%.
OR
Actual EGR Pos is 10% greater or less than the Desired EGR Pos.
Any of the above conditions present for longer than 20 seconds.
Action Taken When the DTC Sets
The PCM will illuminate the MIL during the second consecutive trip in which the diagnostic test has been run and failed.
The PCM will store conditions which were present when the DTC set as Freeze Frame and Fail Records data.
Conditions for Clearing the MIL/DTC
The PCM will turn the MIL OFF during the third consecutive trip in which the diagnostic has been run and passed.
The history DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
The DTC can be cleared by using the scan tool Clear Information function or by disconnecting the PCM battery feed.
Diagnostic Aids
Check for the following conditions:
Open EGR Valve ignition positive voltage circuit. An open in the EGR Valve ignition positive voltage circuit will cause EGR Pos. Error to be erratic while the EGR valve is operating. With the ignition ON, a test light should illuminate when connected between ground and the EGR ignition positive voltage circuit at the PCM connector. If not, locate and repair the open in the EGR ignition positive voltage circuit.
Excessive deposits on EGR valve pintle or seat. Check for deposits that may interfere with the EGR valve pintle extending completely or cause the pintle to stick.
Poor connection or damaged harness. Inspect the wiring harness for damage. If the harness appears to be OK, observe the EGR actual position display on the scan tool while moving connectors and wiring harnesses related to the EGR valve. A change in the display will indicate the location of the malfunction.
EGR valve icing. An EGR valve that sticks due to icing can cause DTC P1406 to be set. If DTC P1406 sets during extreme cold ambient conditions and the DTC P1406 diagnostic table does not isolate the cause of the malfunction, EGR valve icing is very likely the cause. The EGR valve should start operating normally once the engine has reached operating temperature.
Reviewing the Fail Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
Test Description
Number(s) below refer to the step number(s) on the Diagnostic Table:
This step verifies that the fault is present.
This step also verifies that the fault is present.
The PCM contains a recirculation diode which filters the EGR ignition feed for the EGR valve. The recirculation diode is connected to the ignition filter (EGR ignition feed) circuit. If the ignition filter circuit is open, EGR actual position may be erratic when compared to EGR desired position. An open in the EGR ignition filter circuit will cause DTC P1406 to be set after an extended period of time.
If DTC P1406 will only set under certain conditions, the fault may be intermittent; refer to DTC P1406 Diagnostic Aids. If an intermittent wiring problem is not present, check for a faulty connection at the PCM or the EGR valve. If the connections are OK and DTC P1406 continues to set, replace the EGR valve. Go to Exhaust Gas Recirculation (EGR) Valve Replacement .
This vehicle is equipped with a PCM which utilizes an Electrically Erasable Programmable Read Only Memory (EEPROM). When the PCM is being replaced, the new PCM must be programmed.
Step
Action
Value(s)
Yes
No
Was the Powertrain On-Board Diagnostic (OBD) System Check performed?
Go to Step 2
Go to the Powertrain On Board Diagnostic (OBD) System Check
With the engine idling, observe the EGR Actual Pos. display on the scan tool EGR data list.
Is EGR Actual Pos. at the specified value?
0%
Go to Step 3
Go to Step 11
Ignition ON, engine not running.
Select the scan tool Misc. Tests, EGR Control function.
Increment the EGR valve through the 10% through 100% positions while comparing EGR Desired Pos. to EGR Actual Pos.
Does EGR Desired Pos. remain close to EGR Actual Pos. at all commanded positions?
Go to Step 4
Go to Step 6
Turn OFF the ignition switch.
Disconnect the PCM harness connectors.
Turn ON the ignition switch.
Probe the EGR ignition positive voltage circuit at the PCM connector with a J 34142-B Unpowered Test Light connected to ground.
Is the test light ON?
Go to Step 5
Go to Step 33
Connect the PCM harness connectors.
Review and record scan tool Fail Records data.
Operate the vehicle within Fail Records conditions as noted.
Using a scan tool, monitor Specific DTC info for DTC P1406 until the DTC P1406 test runs.
Does the scan tool indicate DTC P1406 failed this ignition?
Go to Step 22
Refer to Diagnostic Aids
Disconnect the EGR valve electrical connector.
Connect a J 39200 Digital Multimeter to measure voltage between the EGR valve ignition feed circuit and the EGR control circuit at the EGR valve harness connector.
Command the EGR to the 100% position with the scan tool while observing the voltage reading on the digital multimeter.
Does the voltage measure near the specified value with the commanded EGR position at 100%?
B+
Go to Step 17
Go to Step 7
Probe the EGR valve ignition feed circuit with the test light to ground.
Go to Step 9
Go to Step 8
Check the fuse for the EGR valve ignition feed circuit.
If the fuse is open, locate and repair the short to ground in the ignition feed circuit. Refer to Fuse Block Details in Electrical Diagnosis .
Was the fuse open?
Go to Step 34
Go to Step 24
Disconnect the PCM.
Check the EGR control circuit for an open or a short to voltage.
If the EGR control circuit is open, repair it as necessary. Refer to Wiring Repairs in Electrical Diagnosis .
Was the problem found?
Go to Step 34
Go to Step 10
10
Check the EGR control circuit for a faulty terminal connection at the PCM.
If a problem is found, replace terminal. Refer to Wiring Repairs in Electrical Diagnosis .
Was a problem found?
Go to Step 34
Go to Step 32
11
Observe the EGR Actual Pos. value on the scan tool.
0%
Go to Step 13
Go to Step 12
12
Disconnect the PCM.
Measure voltage between the EGR pintle position circuit and ground.
Is the measured voltage near the specified value?
0V
Go to Step 31
Go to Step 26
13
Probe the sensor ground circuit at the EGR valve harness connector with the test light to B+.
Go to Step 15
Go to Step 14
14
Check the sensor ground circuit for a poor terminal connection at the PCM or for an open sensor ground circuit between the PCM and the EGR valve.
If a problem is found, repair poor connection or open in sensor ground circuit as necessary. Refer to Wiring Repairs in Electrical Diagnosis .
Go to Step 34
Go to Step 32
15
Probe the EGR control circuit at the EGR valve connector with the test light to B+.
Go to Step 16
Go to Step 22
16
Disconnect the PCM.
Probe the EGR control circuit with a test light to B+.
Go to Step 28
Go to Step 30
17
Connect a digital multimeter to measure voltage between the EGR valve sensor ground circuit and the 5 volt reference A circuit at the EGR valve connector.
Is the voltage at the specified value?
5V
Go to Step 18
Go to Step 23
18
Probe the pintle position circuit at the EGR valve harness connector with a test light connected to B+.
Go to Step 21
Go to Step 19
19
Connect a jumper between the 5 volt reference A circuit and the pintle position circuit at the EGR valve connector.
Observe Actual EGR Pos. on the scan tool.
Is Actual EGR Pos. at the specified value?
100%
Go to Step 22
Go to Step 20
20
Disconnect the PCM.
Check the pintle position circuit for an open or for a poor terminal connection at the PCM.
If a problem is found, repair open in pintle position circuit or replace the faulty PCM terminal(s) as necessary. Refer to Wiring Repair in Electrical Diagnosis .
Go to Step 34
Go to Step 32
21
Disconnect the PCM.
Probe the EGR pintle position circuit with the test light to B+.
Go to Step 29
Go to Step 30
22
Check for poor terminal connections at the EGR valve.
If a problem is found, replace faulty terminal(s). Refer to Wiring Repair in Electrical Diagnosis .
Go to Step 34
Go to Step 27
23
Check for an open or short to ground in the 5 volt reference A circuit.
If a problem is found, repair it as necessary. Refer to Wiring Repairs in Electrical Diagnosis .
Was the 5 volt reference A circuit open or shorted?
Go to Step 34
Go to Step 25
24
Locate and repair the open in the ignition feed circuit to the EGR valve. Refer to Wiring Repairs in Electrical Diagnosis .
Is action complete?
Go to Step 34
25
Check the 5 volt reference A circuit for a poor terminal connection at the PCM.
If a problem is found, replace faulty terminal. Refer to Wiring Repairs in Electrical Diagnosis.
Was the terminal faulty?
Go to Step 34
Go to Step 32
26
Locate and repair the short to voltage in the pintle position circuit. Refer to Wiring Repairs in Electrical Diagnosis .
Is action complete?
Go to Step 34
27
Replace the EGR valve. Refer to Exhaust Gas Recirculation (EGR) Valve Replacement .
Notice
If the EGR valve shows signs of excessive heat, inspect the exhaust system for blockage--possibly a plugged converter--using the procedure found on the Restricted Exhaust System Check. If the exhaust system is restricted, repair the cause. Inspect for an open injector caused by one or more of the following conditions:
Stuck
Grounded driver circuit
Possible faulty control module
If one of the above conditions is found, inspect the oil for possible fuel contamination.
Is action complete?
Go to Step 34
28
Locate and repair the short to ground in the EGR control circuit. Refer to Wiring Repairs in Electrical Diagnosis .
Is action complete?
Go to Step 34
29
Locate and correct the short to ground in the pintle position circuit. Refer to Wiring Repairs in Electrical Diagnosis .
Is action complete?
Go to Step 34
30
Check the pintle position circuit or EGR control circuit for a short to the sensor ground circuit.
If a problem is found, repair as necessary. Refer to Wiring Repairs in Electrical Diagnosis .
Go to Step 34
Go to Step 32
31
Check the EGR pintle position signal circuit for a short to the 5 volt reference circuit.
If a problem is found, repair as necessary. Refer to Repair Procedures in Electrical Diagnosis.
Go to Step 34
Go to Step 32
32
Replace the PCM.
Important:
The replacement PCM must be programmed. Refer to PCM Replacement/Programming .
Is action complete?
Go to Step 34
33
Locate and repair open in the EGR ignition positive voltage circuit to the PCM. Refer to Wiring Repair in Electrical Diagnosis .
Is action complete?
Go to Step 34
34
Clear DTCs.
Operate vehicle within Fail Records conditions as noted.
Using a scan tool, monitor Specific DTC info for DTC P1406 until the DTC runs.
Go to Step 2
System OK
Document ID# 49002
Old Aug 16, 2011 | 10:57 PM
very very nice thought the dumb dumb light is off now and car over heats, i almost believe its time for a new rad.
Old Aug 16, 2011 | 11:42 PM
flush the heck outa the cooling system. did you change the thermostat yet. be a good time to take a close look at it to see if its been catching any crab on it. may be the po mixed the antifreeze and it jelled and is plugging stuff up.
Old Aug 16, 2011 | 11:46 PM
Talking
Yea, crab in the cooling system is no good -- better to catch them fresh and cook them up with some herbed butter...
Old Aug 17, 2011 | 02:54 AM
i just installed a new water pump and also flashed the system before hand, like ive been saying this is crazy its over heating like this, with no signs of internal damage, i checked the rad cap and it seems to spring in ok, so my only guess now is the radiator looks like its Boeing out along the side, but when i flashed the system its got good flow, and for the thermostat i have a 160 failsafe coming in tomorrow ill install and let you guys know
Old Aug 17, 2011 | 10:22 AM
Oh Cod, cut it out you guys! All this seafood double-meaning stuff gives me a haddock.
shaione
Oct 9, 2012 08:33 AM
JPrice
May 20, 2012 03:48 PM
josh75camaro
Jan 7, 2010 09:09 PM
GMDCAMARO
Dec 13, 2007 09:27 PM
