am i missing a relay
Old Oct 17, 2008 | 03:32 PM
evilbeef54's Avatar
Default am i missing a relay
the ABS light is on in my 94 camaro and has been since i got it a few months ago, the cruise controll doesn't work either. I have checked all the fuses, and the wheel sensors appear to all be there with all the wiring connected. I checked the third brake light and it still works. I poped open the relay box under the hood and i only have 6 relays not 7, it appears that imay bemissing the one at position Glabeled ASR/TCSSAME ASABS RELAY, since my 94 does not have tcs, and i do have the other ABS relay at position C do i need the relay at G or not?
thanks
Old Oct 18, 2008 | 01:41 PM
evilbeef54's Avatar
Default RE: am i missing a relay
woops nevermind, question answered, that relay position is not wired up, now on to try to find the cause of my problems
Old Oct 18, 2008 | 10:53 PM
Saint_Ali's Avatar
a relay simply turns stuff on and off, it sounds like someone could have done something with the third brake light, if you put leds in it, its too much output and cause the abs light to blink(not work) and for cruise control not to work either
Old Oct 18, 2008 | 11:14 PM
evilbeef54's Avatar
ORIGINAL: Alih
yea thats why i though it might have been the relay, cause if it is missing it could not turn the abs on, but it appears that that relay is not needed, the entire trunk spoiled deck has been changed on the car, it now has the SS style deck with the led bar light, the wiring is the same 12v going to the third brake light bar, i believe that led bar has the necessary resistors in it to keep it the same, or else it would have to be different circutry for the ss cars, is this not correct? the abs light is no solid, somewhere i heard that it might be someone didn't change a necessary sensor when puting in the 4.10's could this be it, and if so what am i looking for?
Old Oct 19, 2008 | 02:07 PM
Saint_Ali's Avatar
actually i did the same thing, i got a ss spoiler of a 01 and it does it too.you have to put a higher resistor where it plugs into
Old Oct 20, 2008 | 11:51 AM
evilbeef54's Avatar
huh, weird, any idea what size resistor and where did you wire it in?
Old Oct 20, 2008 | 12:27 PM
02StanGT's Avatar
http://forum.camarov6.com/showthread...hlight=spoiler
This thread discusses it as well. May help you.
Old Oct 21, 2008 | 05:22 PM
evilbeef54's Avatar
ah ha, well i'll give that a shot when i get home and see if that relay does the trick, thanks StanGT i'll post up when i give er a try
Old Oct 23, 2008 | 08:05 PM
evilbeef54's Avatar
okay so i followed that link, and put in the 30amp auto relay wired up as shown in the schematic, the "BRAKE" light is gone now, but the "ABS INOP" light is still on?
aboston
Feb 12, 2009 10:16 AM
greenarrow
Dec 29, 2008 12:18 AM
Phil
Dec 28, 2006 06:40 PM
Deezil13
Sep 22, 2006 12:31 PM
