AC wont work!
Old Jun 13, 2007 | 10:43 AM
tyler2497's Avatar
Default AC wont work!
My air conditioner on my 93 z28 turns on and blows air but its not cold at all. I found a leak on the top valve and switched it out with a good one, so now that doesnt leak, I recharged it and still no cold air. Any ideas on what my problem might be?
Old Jun 13, 2007 | 01:32 PM
Default RE: AC wont work!
Does the compressor clutch engage? If not it could be you don't have enough refrigerant in the system, or you have a clutch/compressor problem. If it is engaging and no AC, the system may have moisture in it and freezing internally and needs to be evacuated with a vacuum pump, or the wrong type refrigerant is being used.
Old Jun 13, 2007 | 10:37 PM
tyler2497's Avatar
no the compresser doesnt turn on.
Old Jun 14, 2007 | 09:54 AM
Probably low on freeon and the low pressure switch is cutting the compressor off. Probably need a recharge, but you may have a problem because the 93s still used R12, which is only available to licensed AC repair people.
Old Jun 14, 2007 | 06:46 PM
usarmyrangrs's Avatar
I'd try to manually engage the cluch by jumping the clutch coil wires. Either way, getting an R12 system recharged would be EXPENSIVE, and I'd recommend retrofitting to an updated R134a system. It could very well be the pressure safety switch not allowing the compressor on. All you'd have to do to test it would be to jump the switch and take note whether the compressor clutch engages. If not, you may be looking at a compressor job.
Old Jun 14, 2007 | 10:42 PM
There are several substitutes for R12 that do not require the system to be modified except for screwing on different fittings. One brand I used successfully is Freeze 12. It is available from various part stores and directly on line.
Old Jun 15, 2007 | 01:32 PM
tyler2497's Avatar
It says r134a under the hood on the black peice infront of the radiator
Old Jun 15, 2007 | 10:31 PM
Well that's a bit of good news. R134a is a failry decent priced refrigerant.
Motocrossmom216
Apr 22, 2014 09:17 PM
karma187357
Feb 23, 2013 10:37 AM
pbrMEnow!
Nov 14, 2010 11:04 PM
66Fastback
Jul 15, 2008 07:34 PM
Camaro Man 1999
Feb 5, 2008 12:08 AM
