AC Freon leak
Old May 5, 2010 | 07:27 PM
RFxCamaro's Avatar
Default AC Freon leak
I have a freon leak that i cant find. I recharged my ac and in about 3 days it was gone. I went out and bought some uv leak detector. Charged my ac again and added the detector. Hasnt leaked yet as i can tell. I drove it about 20 miles and dont see any leaks. Im using a blacklight and still cant see any leaks. My car is a 1996 3.8 and was wondering if there where any common leaks in these cars or any info you guys might have.
Old May 5, 2010 | 07:44 PM
Compressor clutch (front of compressor), Condensor (stone chips) , Lines around the back of the compressor.
Old Jun 4, 2010 | 10:25 PM
traumadog's Avatar
Bump for an older thread... but does anyone know any tips to get at the bolt holding the lines to the back of the compressor? (3.8 V6 particularly)
Old Jul 19, 2010 | 03:51 AM
RFxCamaro's Avatar
ok so i checked eveywhere underneath the hood, is there anywhere under the dash it could leak?
Old Jul 19, 2010 | 10:36 AM
Yes, evaporator core, pressure hoses/pipes & connections to the core.
Old Jul 19, 2010 | 11:43 AM
dopez28's Avatar
if it was the evap you should be able to smell it and might burn your eyes a bit when the ac is running from it leaking. try to look around the compresor and look for oil spots. if ya still cant find anything id take it to a good shop and have them check with a leak tester.
Old Jul 19, 2010 | 05:59 PM
Grandpaswagon's Avatar
Any decent shop can put in some dye and find the leak for you. It may cost $100 bucks or so, but it is better than throwing parts at it hoping you get the right one.
I didn't have very good luck with store bought dye years ago. I don't know if I just didn't have the right light or what, but I could not get it to flouresce. But the dye that my local shop uses lights up like a green monster with their light. Plan as day to see that my compressor is leaking like a sieve.
Old Jul 19, 2010 | 10:03 PM
RFxCamaro's Avatar
ok like a dumbass i never checked under the car, i followed a trail to the compressor, now i just need to replace it
Jelz28
Jul 18, 2012 06:01 PM
stox58
Apr 18, 2011 08:46 PM
impalassv8
Aug 27, 2010 04:24 PM
skar
Aug 27, 2007 11:10 AM
Robby93
Sep 21, 2006 01:14 AM
