ABS Question
Old Jul 14, 2011 | 09:32 AM
greenarrow's Avatar
September 2009 ROTM
If you don't run the brake system low on pressure then you won't need to a computer to bled the brakes. There are several different computers out there that can be used to bled the brakes, not just ones that dealers have. I had a small BFE shop that used to do mine with a little $3K computer, can't remember what it was now.
If you're going to get back into the brakes, you might as well replace the stock rubber lines with SS braided lines. Older rubber lines will give you that squishy feeling.
Old Jul 14, 2011 | 02:57 PM
Grandpaswagon's Avatar
So, if I understand correctly, if I don't have an ABS code set, and I keep the engine off, I can bleed my brakes just like I used to do with my '64 Nova? Sounds like a plan for next weekend.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
