94 Z28 6speed jerking on high acceleration
Old Jul 14, 2011 | 02:51 PM
lbclt1's Avatar
Default 94 Z28 6speed jerking on high acceleration
help! my 94 z28 is jerking when I accelerate and the clutch is fully released...for some reason if I keep the clutch pressed down a bit while accelerating it doesn't jerk, it happens mostly on 1st gear and sometimes on 2nd gear. It's embarassing, if Im on a red light and try to accelerate to cut of the lane over it jerks (stalls) then continues to go....it also has a bad smell....a mechanic I went to says its a missfire?
Old Jul 14, 2011 | 06:07 PM
Misfire sounds just about right. Time for plugs & plug wires. If that does not work you may have to look at fuel delivery and maybe a new opti.
Old Jul 14, 2011 | 10:02 PM
^^^ agree, how old are the opti, plugs and plug wires? sure sounds like a bad wire failing under high stress.
rs657f
Nov 21, 2014 02:26 PM
LinearCitrus
Jun 18, 2012 08:13 PM
Wayne350
Mar 13, 2012 07:57 AM
Goodfella
Oct 18, 2007 07:21 AM
oicunvme
Apr 30, 2007 02:06 AM
