99 Z28 Interior Light Dead : Ashtray/PRNDL
Old Dec 18, 2007 | 07:18 PM
Lacunaa's Avatar
Default 99 Z28 Interior Light Dead : Ashtray/PRNDL
Anyone know if this is a pain to replace or exactlywhere it is ? Could this just be a fuse ?
Car is 99 Z28
Thanks for any help
Old Dec 18, 2007 | 09:02 PM
02StanGT's Avatar
Default RE: 99 Z28 Interior Light Dead : Ashtray/PRNDL
I've seen them listed as two different lights, but I'm not sure where the ashtray light is. The gear indicator light is fairly simple to replace. Open middle compartment, remove coin holder, unbolt two bolts, lift up console enough to remove light. Bulb is a pain to remove socket though.
Old Dec 18, 2007 | 09:35 PM
Lacunaa's Avatar
Thanks for the info
I was thinking it was the same bulb because both the ashtray and gear light went out at the same tame
At first I could hit the console and make it come back on , but now that doesnt work at all
If it was a fuse, it would be affecting more lights/systems correct ?
Old Dec 18, 2007 | 09:46 PM
02StanGT's Avatar
That's correct. Some of the smaller bulbs in which the filament didn't burn completely away, can be jarred to come back on. Though this happens only sometimes, and doesn't last for long. The location for the bulb is right under the 1 on the gear indicator. I believe the bulb is 75, I just replaced mine with an LED as well as the door switch panel lights.
Old Dec 19, 2007 | 01:38 AM
Lacunaa's Avatar
Will an auto parts store carry the bulbs/ LEDs ? Or is this a dealer item ?
Why did you choose LED and is there any modification needed to install ?
Old Dec 19, 2007 | 01:52 AM
02StanGT's Avatar
Stores will carry bulb, not sure of LED though. I got mine of eBay. White LED gave a slight blue tint to the letters. I chose LEDs, as they last a hell of alot longer than regular filament bulbs, and look better in my opinion. No modification to install them.
SRQTerry
May 26, 2013 09:59 PM
cooleric2000
May 26, 2012 10:52 PM
FyrfytrFil
Jul 14, 2010 02:52 AM
cautioncones
Dec 7, 2008 01:38 PM
