99 Manual Transmission Leak
Old Apr 17, 2018 | 08:56 AM
JoeMunger's Avatar
Default 99 Manual Transmission Leak
My 99 v6 manual Camaro stopped going into gear, I thought the problem was the clutch fluid hydraulic line (connecting the master cylinder to the slave cylinder), so I replaced it. Then once I tried to add dot 3 fluid and bleed the system it started leaking, the fluid comes out slow and drips from the transmission. Any suggestions on what it might be would be appreciated. Thanks.
Old Apr 17, 2018 | 10:07 AM
either the line is not in right or the slave cylinder is leaking. may want to replace all at once, master, slave and line.
Old Apr 17, 2018 | 11:28 AM
It is kind of a big job since the slave is part of the release bearing but at 20 years old it would be considered normal if its original.
CamBigCat
May 28, 2016 02:04 PM
Jelz28
Jul 18, 2012 06:01 PM
trash
82-92 V8 Tech
Jan 6, 2006 11:48 PM
crhumper
Sep 8, 2004 11:27 PM
