97 camaro put up for the winter
Old Nov 23, 2008 | 09:45 PM
DUB C's Avatar
Default 97 camaro put up for the winter
Well I had a few concerns about putting my camaro up for the winter. I am using a battery maintainer instead of taking the battery out of the car. It stays plugged to the car on what they call a float mode.Any comments on this. I also put my car up on jackstands and i see that there is what looks like a hard plastic pad in the front for my stands - however in the back where is the best places to put them.
Old Nov 23, 2008 | 09:57 PM
Saint_Ali's Avatar
Default RE: 97 camaro put up for the winter
if you do decide to leave it in the car, it is best to disconnect the negative cable, that way the battery drains not as much
Old Nov 23, 2008 | 10:22 PM
When storing the car on stands, you want it supported from the suspension, not the frame/body. So, you won't be using those front jack pads anyway.
Put the jack stands under the rear axle tubes, and under the front control arms.
Old Nov 23, 2008 | 10:28 PM
DUB C's Avatar
Well crap that sucks i have the jack stands on the body/frame - i did this today - will there be any problems if i leave it like that until i can get back to it again
Old Nov 23, 2008 | 10:54 PM
A short while won't hurt it. When you jack up the car by the body, all the suspension components extend out. That leaves things like the shaft of the shocks exposed in a spot where they normally wouldn't be. If those then rust, you can wind up with some leaky shocks.
By the suspension is also a good idea because that's the way the car supports itself naturally. Hanging the car on it's frame can leave yourself open to any possible body "tweaks".
jmantra
Feb 16, 2012 12:02 AM
montecarlogrrl
Oct 16, 2010 10:55 PM
1quik4
Sep 17, 2010 10:32 PM
auto
Dec 9, 2009 10:11 PM
JJ_77
Nov 17, 2007 03:31 PM
