96..security system won't disarm
Old Jan 19, 2010 | 12:18 PM
caridiot's Avatar
Default 96..security system won't disarm
Is there anybody that can help me with this?? Like it says, I have a 96 camaro and the security system won't disarm. I've had it to the dealership 4 times now and they can't fix it. Sometimes it starts, sometimes it doesn't. There is no rhyme or reason to it. Sometimes the security light is solid, sometimes it's flashing. I just paid $800 for them to replace my BCM and that lasted about 5 weeks. I read somewhere that it can be disarmed if you disconnect it at the starter but the dealership says it's not true. HELP!!!!!
Old Jan 19, 2010 | 04:36 PM
ghostpopi's Avatar
Old Jan 20, 2010 | 06:27 AM
caridiot's Avatar
Default Thank you
I'll give this a try!!
Old Jan 21, 2010 | 06:17 PM
osduck5's Avatar
Ohm your key to make sure that the chip is not bad. We had a key that would work at times and other times would do exactly like you say. Dealership told me that there was no way it was the key. I ohmed it out and it showed good. I tried it again and it showed no resistance. Had new key made and no more issues.
Old Jan 22, 2010 | 06:22 AM
caridiot's Avatar
Thanks for your advice. I appreciate it. A year and a half ago this happened to me and the dealership put in a new ignition and cut me a new key. I think I'm going to try the "bypass" route. This has been an ongoing issue for the last year and I just want it disconnected once and for all.
Old Jan 22, 2010 | 06:42 AM
do a computer tune and have it removed/turned off while there doin it.
Old Jan 23, 2010 | 11:02 AM
ghostpopi's Avatar
he has a 96 craby you can't tune a 96 comp. or can u?
Old Jan 23, 2010 | 05:23 PM
yes u can cost 250 bucks and 15 shipping.
http://www.pcmforless.com/index.php?...ebird%20Tuning
Old Jan 23, 2010 | 05:37 PM
ghostpopi's Avatar
ok
1996 V6 Tuning :
Our performance tuning for the 1996 V6’s typically yields 10-14hp and 1-3mpg (stock vehicles, more if modified), as well as better part throttle response, driveability, and more pep off the line. We can also account for any modifications you might have. After placing your order, you will be redirected to an ordersheet to fill out with your vehicle's information. In the case of 1996's we will send you a computer, you do not need to send us anything. Price includes spare computer. Your 1996 PCM is not eligible for core credit. cost $225
James Thew
Aug 29, 2012 10:03 AM
husker_camaro95
Feb 3, 2011 07:29 PM
95redz28
Mar 18, 2010 10:11 AM
Levithain
Dec 1, 2008 12:38 PM
jkerr
Jun 2, 2006 11:34 PM
