tire pressure?
Old Jan 16, 2010 | 01:24 PM
Dappled Apple's Avatar
Default tire pressure?
So I have a 1997 base v6 with 235/55/r-16 sumitomo htr h4 tires, what tire pressure should i be at? i just checked and i was at 25.5-27.5psi all around and we couldn't find the tire pressure label in the glovebox, door jambs, or gas cap areas.
Old Jan 16, 2010 | 06:48 PM
whats the max pressure for the tire. i run mine at about 40 and the max is 50. most guys run em around 35.
Old Jan 17, 2010 | 12:17 AM
I tend to run mine higher than the car manufacturer recommends as well. Usually between 36~38, depending on the limit of the tire. More air will give you better gas mileage, but a harder ride. And way too much air making the tires rock hard can cause them to act a little greasy in a swift turn. Experiment.
Old Jan 22, 2010 | 11:40 PM
hmm well mine are all at 31-32 now and i kind of like it, but i dont know whats the manufacturers recommendation?
Old Jan 23, 2010 | 07:24 AM
Cork's Avatar
I run mine between 32 and 35 and find that a nice compromise among road feel/handling, ride, and economy.
Old Jan 23, 2010 | 08:49 AM
Per the FSM:
Front & rear
30 PSI cold normal driving
32 PSI cold high speed driving
compact spare 60 PSI
Wheel nut torque 100 lb. ft. (alloy or steel rims)
Don't go by the pressure shown on the tire. That is the maximum safe pressure and it will give a lousy ride and poor handling. The best pressure is the one that will give even wear across the tire. High pressure will cause the center to bulge out and wear first. Low pressure will allow the center be lower than the sides and the sides will wear first. Proper pressure will give even wear across the face of the tire, and best handling due to more rubber meeting the road. All this assumes correct wheel alighnment.
Old Jan 23, 2010 | 01:35 PM
auto's Avatar
I ran 35 hot
Old Jan 23, 2010 | 05:35 PM
All depends on how hot the tires were. 35 PSI hot may turn out to be on the low side when checked after the tires cooled. For street cars tire pressure should always be checked after the car has been standing for a good 4-5 hours, like first thing in the morning. For racing purposes the pressure is checked and adjusted at running temp, and is adjusted according to conditions, this would be a real PIA for a street car.
Old Jan 23, 2010 | 05:52 PM
maudyZ28's Avatar
i'd run what pete says bout 30-32, mine are 32 and i have 255/35/18 on some bmw rims.
Craby do you seriously run 40 PSI, how the hell does your car turn, its really bad to run tiress over inflated, wears the middle out and less contact patch on road, ^^^ what pete says
Old Jan 23, 2010 | 06:36 PM
they wear fine and the car handles great. dont like the tire roll on a underinflated tire and the tires are made for a little higher pressure. the guys at the shop put them at 28 once and i could really tell the difference on the corners. less responsive. i like em at 38 to 40.
