95 z28 noise
Old 10-09-2015, 08:05 AM
torque_is_good's Avatar
Originally Posted by Casey Hart
With the engine running method
you removed both valve covers including moving the alternator and then re-installing it on the passenger side, started engine, loosened nut until you heard clack clack clack, then tightened nut until it went away and then another 1/4 turn, and did that on all 16, correct?
Did you then increase rpm's to verify no more clack clack clack (that's a technical term btw)?
Did you also verify good oil flow coming up through the push rods?
if you were that close, and heard no valve train noise, and did the adjustment as i asked, and verified good oil flow, if if if, then without being there and having to place a bet, I'd go with exh leak or noisy accessory.
Only you know for sure how you did the adjustment and what you observed as well as what you hear under the hood. Youtube videos are good but not as good as being there in person
If you hear the sound from inside the car then you'll hear the sound from under the hood. Snug up the header bolts and listen. After that, remove the belt(s) and run engine for not long and increase rpm's and see if the noise goes away without accessories.
Sure it's a pain in the butt but you need to follow a process of elimination
Old 10-09-2015, 11:47 AM
from what will play with this computer today it sounds like a exhaust leak or lose spark plug.
Old 10-09-2015, 02:44 PM
95 camaro 406's Avatar
wonder ,sounds like i agree plugs wires replace them i think you said you were that should get you feeling better hopeing
B_Dubya
03-27-2015 02:10 PM
Eagle564
09-13-2011 01:16 AM
auto
LS Series Tech
12
10-11-2009 08:07 PM
Burton158custom
07-08-2008 02:23 AM
RisingSt0rm
03-26-2008 07:46 PM
Quick Reply: 95 z28 noise
