LT1/LT4 Tech 1993-1997
94 Z28 Noise
Old Jun 17, 2008 | 02:43 PM
Burton158custom's Avatar
Default 94 Z28 Noise
There is a Shuddering knock and ticking noise from the engine theres 57,000 miles on the engine everything is stock and i jsut bought it 2 weeks ago ive been told that im down a cyl and wanted to know what could be wrong
ive changed-Spark plugs,Fuel filter,intake filter,oil&filter
Old Jun 17, 2008 | 03:38 PM
robmnrd's Avatar
Default RE: 94 Z28 Noise
Change plug wires, and run injector cleaner.
Is the knock just a sound, or can you actually feel it?
Old Jun 18, 2008 | 01:03 PM
its not the wires i checked all cyl are firing. and ran fuel injector throught im thining its injectors them selves or the valves
Old Jul 6, 2008 | 01:15 AM
Justin_97_CamaroSS's Avatar
if it is at idol or does the knock get louder with accelration.? could be fpr
Old Jul 6, 2008 | 11:18 AM
If all the cylinders are getting proper fuel and spark, and you are sure one cylinder is not firing (dead), then that cylinder probably suffered mechanical problems. Do a compression check & see if a bad cylinder shows up. The noise could be a problem with the valve gear, which could also result in a dead cylinder.
Old Jul 8, 2008 | 02:23 AM
hey could a dead cylinder feel like a little skip every now and again??
B_Dubya
Mar 27, 2015 02:10 PM
DashingDaryl
Apr 4, 2012 02:46 PM
AKLDan2k1
Aug 23, 2011 07:56 AM
supreme_style21
Jun 8, 2010 06:36 PM
EddieTheRipper
Oct 11, 2007 08:57 PM
