95 Z28 with 700R4????
Old Sep 6, 2010 | 01:21 PM
Vandee's Avatar
Default 95 Z28 with 700R4????
so im looking into buying a 95 Z28 so i called the guy today and he said that it had a shift kit in it when i asked him about it he said it had the 700r4 with a stall but he removed the stall and put it back to stock......i thought that only the 93 have the 700r4 the 95 should have the 4L60e correct would it even be possible that someone swapped that tranny in? wouldnt the computer not know what to do?
Old Sep 6, 2010 | 01:56 PM
Vandee's Avatar
also he says the engine is stock. i just read something saying that in order for you to use the 700R4 on a 95 ud need a different TB? so does the guy just not know what he has?
Old Sep 6, 2010 | 02:19 PM
TransAmGuy95's Avatar
I don't know if a 700r4 would bolt up perfectly mine came with the 4L60e as well and its a 95. All the automatic lt series cars ive ever seen also has it. My buddy's third gen has a 700r4 but thats an 80's car. A 4L60e is basically a 700r4 with more electronic componets in it.
Old Sep 6, 2010 | 02:51 PM
In 93 GM put the 4L60 in the Camaro. The 4L60 is just another name for the 700R4. It is pretty common pratice to change the name of somthing that has had a lot of problems. The 4L60e is just the electronic control shift version of the 700R4. Most of us that have been working on these things since the early 80's still call them 700R4s. Most likely the guy is just calling it a 700R4 cause him or a buddy of his is old school.
Converting to a 700R4 is doable but would be a huge pain computer wise.
Dakota_Don
Apr 3, 2010 12:46 PM
359pete
Feb 15, 2009 12:58 PM
kyleag89
Jan 16, 2009 01:10 PM
sinisterRS
Apr 15, 2008 03:45 AM
HaloNick
May 1, 2006 06:09 PM
