95 Z28 5.7L -Coolant light on dashboard
Old Oct 21, 2011 | 09:59 PM
ZedNorth's Avatar
Question 95 Z28 5.7L -Coolant light on dashboard
Luv my Zed, bought it a year ago and since put about 25,000Km's on it.
Coolant light on dash won't go out... rad and overflow are both full.
My guy says sensor in bottom of overflow is all gummed up.
Is he right..?
Any advice would be appreciated,
ZN.
Old Oct 21, 2011 | 10:02 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Pretty much right. Its a very very common issue on the LT1 engines. They get gummed up. You can just unplug it or you can remove it and clean it, or simply replace it. Depends on how deep you feel like going into it
Old Oct 21, 2011 | 10:24 PM
ZedNorth's Avatar
Thanks mr. Nj85z28..!
I'm guessing the connector that needs cleaning must be at the bottom of the overflow and can be reached from underneath..?
NZ.
Old Oct 21, 2011 | 10:41 PM
RFxCamaro's Avatar
If it got gummed up you gotta wonder why. Check the coolant for notorious dexcool sludge.
Old Oct 24, 2011 | 07:39 AM
coolant level sensor is on the passenger side if the radiator just below the radiator cap.
http://shbox.com/1/low_coolant.jpg
Old Oct 26, 2011 | 07:15 AM
ZedNorth's Avatar
Ah ha... I see said the blind man.!
Thanks again. I'll try it and will be sure to let y'all know.
Yours truly,
ZN
Old Oct 26, 2011 | 10:53 AM
charlie94's Avatar
wish I would havr read this before I posted. would this cause the temp gauge to not work as well
Old Oct 26, 2011 | 01:17 PM
ryguy425425's Avatar
My guess would be no. I ran my car for the first few months I had it with the coolant light on, and the sensor has been unhooked for about 2 1/2 years. The car runs strong and the temperature gauge worked both before and after I unhooked the sensor.
amwatchinya
Feb 25, 2015 04:18 PM
sebi1990
Jan 23, 2011 03:17 AM
longarmperrin
Dec 10, 2010 07:24 AM
xXChipXx
Oct 25, 2010 01:05 PM
evilbeef54
Jul 27, 2008 09:47 PM
