95 engine troubles
Old Feb 23, 2008 | 09:25 PM
grif's Avatar
Default 95 engine troubles
is there any engine toubles with the 95 v6 3.4 or 3.8 L engines or head gaskets ?
what damage can a leaky head gasket do even after replacement?
Old Feb 23, 2008 | 09:38 PM
meteoralp45's Avatar
Default RE: 95 engine troubles
im confused about what your saying? did you get a gasket replaced nd its still leaking?
Old Feb 23, 2008 | 11:42 PM
grif's Avatar
im looking at buying a used 95 v6 camaro and the owner has recently replaced a head gasket....i want to know if any problems can come up becouce of the head gasket leaking before.
Old Feb 23, 2008 | 11:59 PM
ninetysixyenko's Avatar
how much?
i wouldnt worry to much about it if it's for a good price. alot of the 3.4s and 3.8s "leak" (meaning drip drop every once in a while) after a certain mileage point, regardless of what you do. also, replacing seals again isnt that hard to do, or expensive.
gregcherrry
Dec 13, 2010 11:09 PM
blaclabel250
Aug 21, 2007 01:44 PM
HAULINanBALLIN
May 9, 2007 12:55 PM
89 Iroc Conv
82-92 V8 Tech
Mar 15, 2007 11:22 PM
86camaro
Sep 12, 2005 07:21 PM
