95 camaro high RMPS 2600-3000
Old Feb 25, 2008 | 10:11 PM
giants4life07's Avatar
Banned
Default 95 camaro high RMPS 2600-3000
ok my car is acting very weird my car idles really high rpms it stop a 3000 and does not go down! when i dirve it it runs by it selfs kinda like a auto cruse control! i have to break hard to stop her! my check engine light is on it reads coolant high I change the ECT sensor..
it starting to run a bit better I got a new Idle Sensor think might solve i was think of getting a new Crankcase sensor as welll
Old Feb 25, 2008 | 10:49 PM
95slvrZ28's Avatar
Default RE: 95 camaro high RMPS 2600-3000
Check the throttle position sensor as well, sounds like that could be a culprit. Is the SES light still lit?
Old Feb 25, 2008 | 10:55 PM
ninetysixyenko's Avatar
um um um..
isnt this the same person who added jet fuel to his 3.8?
Old Feb 25, 2008 | 10:57 PM
95slvrZ28's Avatar
Yenko, he's back for help, try to help and not start that whole fiasco up again...but yes it is...
Old Feb 25, 2008 | 11:00 PM
ORIGINAL: 95slvrZ28
ok, was just making sure. lol.
it could be the MAF too, couldn't it?
Old Feb 25, 2008 | 11:04 PM
95slvrZ28's Avatar
Usually when the MAF is going bad the PCM will start to ignore the bad signal. Something he could try is unplugging the MAF, this will make the car default to the MAP in which case it should run close to normal off the preset fuel maps.
Old Feb 25, 2008 | 11:07 PM
[8D]
learn something new every day. i just remember working on my dad's 86(now cus's) and his MAF went bad one time, and he was idling around 3k RPM. he knew right away what it was though.
Jan 25, 2014 11:09 PM
ShadowCat
2010+ V8 Tech
Sep 10, 2010 02:13 PM
Z-28drivertexas
Mar 15, 2005 02:58 AM
