95 camaro 3.4l v6 cranks but will not start.
Almost all parts made for a 1995 car with be discontinued by GM. Crankshaft sensor are made by the after market. Any parts store will have them. Rock Auto shows 3 or 4 manufactures that make them.
Are you sure you do not have spark. Spark testers are easy to use and cheap to get. Any parts store will have them a harbor freight will have them for under 5 dollars. Stop throwing parts at the problem you need to figure out what not there (spark, fuel or compression) then figure out why its not there. Crank sensor are easy to test. Just check youtube. With searches like. How to "test for spark" "How to check fuel injector". a manual will help also. Don't forget this is almost a 30 year old car that was design to last 10-12 years. Wires and connecters are also subject to time. Plus the more you move stuff around replacing stuff the more chances you have of causing problems. Back when I was a tech the last thing I wanted to see on a "no start" was a bunch of new parts.
