95 camaro 3.4l v6 cranks but will not start.
Old Jun 1, 2023 | 05:09 PM
Reggie88's Avatar
Default 95 camaro 3.4l v6 cranks but will not start.
Okay this is all i have done, starter, fuel pump, fuel filter, fuel injectors, spark plugs, alt., a/c compresser and lines, water pump, power steering pump, all fuses and relays, condenser, cleaned the fuel lines, it went down about 4 yrs ago due to a coolant leak, and got another car but i did the work in 2022, some aminal chewed at some wires by my battery, but i replaced that too, can anyone help with my problem?
I replaced the coil packs and the icm and spark plug wires too.
Old Jun 3, 2023 | 07:53 AM
are you getting spark to the plugs when cranking over the engine?
Old Jun 3, 2023 | 09:05 AM
Reggie88's Avatar
Yes, i changed coil pack wires, and plugs tested computer too.
Old Jun 3, 2023 | 09:10 AM
Can you hear the fuel pump come on when you turn the key to on?
Old Jun 3, 2023 | 01:30 PM
Reggie88's Avatar
Yes and its keeps 40 psi of pressure
Old Jun 3, 2023 | 08:28 PM
I got nothing,if you have spark and you have gas even if the timing was off it should at least backfire.
Old Jun 5, 2023 | 01:04 AM
are the injectors being told to fire? if you haven't tested pick up injector noid light at local parts store,
Old Jun 5, 2023 | 12:42 PM
But does it work? By computer I assume you mean the spark module. The tests are not 100% and if they were you have only tested about 25% of what makes spark. You need a spark tester. Maybe you did that it just not clear?
Old Jun 11, 2023 | 03:15 PM
cwilt's Avatar
Crankshaft or camshaft position sensor?...if you confirmed you don't have spark.
Old Jun 11, 2023 | 05:44 PM
stick a screw driver in the plug wire grab the metal part and turn her over.... lol umm if you are old,,, dont do it,.. lol. hold the plastic part and move the metal part close to metal on the engine like exhaust manifold, turn her over and see if its sparking.
