95 camaro 3.4 nothing happens when turn key
put new regulator in drivers door. when done turned key. cranked for about 20 sec turned key off, turned key again nothing, noidiot lights no crank. key chime and head light chime work. check ign and pcm fuses and where good. checked batt cables also. anyone got any ideas. thanks
check the small wire at the starter for voltage when the key is turned to the start position. you will need a helper to hold the key while your under the car. if you have voltage at the small wire then most likely your starter decided to go. check for voltage at the big wire on the starter. should have same voltage as the battery. while your at it short the large wire connection to the small wire post. starter should turn over so be ready. also be ready for some sparks an dont ground the connection or you will get some big time sparks.
