95 3.4 Camaro Hard to Shift
Old Dec 27, 2010 | 09:25 AM
wallace.john.w@gmail.com's Avatar
Default 95 3.4 Camaro Hard to Shift
The car is having a hard time shifting into 1st or Reverse. Anyone else have this problem.
Just bought the car for a decent price and would like to restore it and do a LT1 swap if possible.
Old Dec 27, 2010 | 10:30 AM
BasicConcepts's Avatar
Technical User
Auto or manual and I'd forget about the V8 swap its not easy and will cost you somewhere between 5 and 10 grand these cars are very specific to there drive train
Old Dec 27, 2010 | 10:35 AM
Its the 5 speed manual.
Old Dec 27, 2010 | 11:16 AM
Technical User
first thing that comes to mind is the clutch actually i guarantee the clutch in some form unless your trans is completely messed up
weather its the slave cylinder or the pressure plate it could also be the throwout bearing how many miles on the car do you know when the last time the clutch was changed if ever
ill sell you a stage 2 racing clutch worth 285$ with only 8k miles on it the master and the slave cylinders for 175$$ plus shipping
(being serious here)
Old Dec 27, 2010 | 12:41 PM
Chaotic94's Avatar
September 2011 ROTM
Before you go replacing parts, go to a shop and have the clutch power-bled
Old Dec 27, 2010 | 01:12 PM
I also feel some vibration in the clutch pedal.
Old Dec 27, 2010 | 01:17 PM
Chaotic94's Avatar
September 2011 ROTM
When the gears are engaging? Or while going down the road? Or at idle? Or??? We need more info.
Old Dec 27, 2010 | 02:00 PM
Technical User
actually isnt first and rev on the same thing (i dont know what to call it there connected together sort of is it syncro im not really sure what that is either) anyways if so id say it may be the trans
Old Dec 28, 2010 | 08:08 AM
Hard to get into first or reverse at idle. Don't really use either of those gears while going down the road
Old Dec 28, 2010 | 08:17 AM
Also at Idle when trying to go into reverse without the clutch depressed it doesn't stop me from attemping to go into gear like it does in the other gears. It is just open.
DashingDaryl
Sep 20, 2012 01:18 PM
dragonslayer
LS Series Tech
Feb 9, 2012 01:11 AM
apetsel
Mar 25, 2011 06:27 PM
DarlingReject
Aug 26, 2009 12:27 PM
importhunter1300
Aug 10, 2005 11:35 PM
