94z no crank no start no nothin
Old May 30, 2019 | 08:54 PM
btrecordingz's Avatar
Default 94z no crank no start no nothin
Beating my head against a wall here. Car sat for about a year and now wont do a thing. Can run fuel pump by jumping the relay, can crank with starter relay jumped. No spark at all, no fuel getting to engine. Fuel pressure at 60+ with pump running. Hotwired ignition switch connector and get radio, crank, and fuel pump but no start. Whole time gauges do absolutely nothing. Really want to get the car going again. Any ideas?
Old May 31, 2019 | 06:59 AM
sounds like the antitheft system is engaged. look at 26 27 28 here 4th Gen LT1 F-Body Tech Aids
Old May 31, 2019 | 01:07 PM
I doubt it. Disabled vats in tunercats, tdr bypassed, and has a resistor in the key line. Fuses are also all fine.
Old Jun 12, 2019 | 03:17 AM
check your ignition switch make sure you got power goin in and out.
FastEddie313
Jul 17, 2019 04:01 PM
Everett#2390
Mar 29, 2017 09:51 PM
Camaro1969
Apr 20, 2015 04:21 PM
RedRocket98
Jul 29, 2010 10:14 PM
kamaro68
Jan 24, 2008 05:57 PM
