94 z28 problems
Old Jul 15, 2010 | 01:18 PM
jason smith74's Avatar
Default 94 z28 problems
the problem is that at a dead stop i can hit the gas farly hard and it sounds and feels like something is slaming into the bottom of the car around the concole area but it doesnt do it when your moving and hit the gas it acts normal any have any ideas what it could be or maybe had this problem befor
Old Jul 15, 2010 | 01:23 PM
Broken transmission mount or broken torque arm bushing.
Old Jul 15, 2010 | 01:46 PM
agree with pete,,, its the transmission mount. easy to change and cost 15-18 bucks.
Old Jul 15, 2010 | 01:53 PM
i just checked all the mounts and there good i even crawled uder the car and tried to shake it and i couldnt buge it were is the tourque arm bushing at
Old Jul 15, 2010 | 02:21 PM
You need to push the tranny up with a jack. I don't think you are strong enough to bounce the entire engine & transmission assembly. The torque arm bushing is a rubber cushion affair at the end of the torque arm where it connects to the transmision. The transmission mount connects the transmission to the crossmember. Change both of them out for best results.
Old Jul 15, 2010 | 02:23 PM
its got a conciderable anount of weight on it. i doubt you will be able to move it. lift the tranny a little and undo the 4 bolts on the side, i would put money on it being broke.
Old Jul 15, 2010 | 02:32 PM
ok thank you guys for your help ill replace them and c if its the problem
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
