94 V6 Gas Mileage
#21
My car has 18" C6 corvette rims on it. I dont have any stock rims for the car. Ill take the tire and jack out though. Code scanner i used was NOT for 96 and newer it was for the GM OBD 1 computers and the car is on its list of working to scan and give codes.
#22
ok, 94 can be a pita to find a scanner that will work on em. i don't see how the weight of the jack and tire is going to make much difference. 40 lbs,,, that weighs same as 5 gallons of gas. have you tested the fuel pressure yet?
#24
What viscosity oil are you running? When was the last time trans/rear gear oil were changed? Might be able to pick up a few changing them out to synthetic if they're overdue.
#25
I have no info on the car before 148,848 or whenever i got it. When i did the pan i put 5w 30 in it. Runs at normal oil pressure levels. Trans im not gonna mess with. Gear oil i dont know how to change and would rather someone with knowledge of the cars helps with that.
#27
I work at autozone and the scanner we sell for OBD1 GM cars said mine is able to be read but the one we use for customers cars if needed doesnt read my car. Would in my 93 sunbird but not this camaro.
#28
