94 Camaro starts running rough after warm up
Old May 12, 2012 | 08:17 PM
  #21
BasicConcepts's Avatar
Technical User
no the 95 is in between obd 1 and 2 its funky an obd1 computer with and obd2 port... a major pain in the *** (try finding someone that will scan a 95 for less than 100$)
Old May 12, 2012 | 08:49 PM
  #22
CZimmer's Avatar
I was just doing more looking on the net and found the 94 is just the opposite of that. "94 3.4's Use The Obd-1 Connector But The Obd-ii Baud Rate".. Does that sound possible?
Old May 12, 2012 | 11:26 PM
  #23
The way it works:
1) Up to and including the 93 models are OBDI, and the codes can be flashed.
2) 94 are straight OBDI but will not flash codes. A real scanner is needed, plain code readers won't work.
3) 95 are OBDI, but use a OBDII test connector. So you need an OBDI scanner with a cord that has an OBDII end, or a scanner that does both OBDI and OBDII.
4) 96 and newer are straight OBDII.
5) If using a PC you will need the proper software and a cable to fit the type of test port your car uses.
Old May 12, 2012 | 11:48 PM
  #24
CZimmer's Avatar
z28pete thanks!
Old May 13, 2012 | 05:50 PM
  #25
CZimmer's Avatar
Does anyone know if an INNOVA 3120 Diagnostic Code Scanner would work on my 94 camaro?? I wanna know for sure before I purchase it.
Old May 13, 2012 | 05:58 PM
  #26
Technical User
the 3140 is better it has live data feed which means you can plug it in drive and see what your car is doing at that time but if thats not important get the 3120
Amazon.com: INNOVA 3140 Diagnostic Code Scanner for OBDI and OBDII Vehicles: Automotive
to me the data log is worth the extra 50 bucks
Old May 13, 2012 | 07:46 PM
  #27
CZimmer's Avatar
I didnt even see the 3140.. But it will for sure hook up? Cuz ive seen some gm conectors that have these slopes on the plug and don't fit.
Old May 14, 2012 | 12:13 AM
  #28
i have a 3140 and it would not scann a 95. does the 93 but only shows codes, does not have running info like my 97 truck shows on the same scanner.
Old May 14, 2012 | 11:23 PM
  #29
CZimmer's Avatar
Craby do you know if it would work on a 94?
Old May 15, 2012 | 06:49 AM
  #30
if memory serves me correctly bc had a 94 so im assuming it worked on his. have not had an opportunity to use on a 94.
RedSled99
Sep 28, 2013 11:37 PM
XxCaMeLxxToSiSxX
Dec 8, 2010 09:28 PM
Mesosneaky
Jul 29, 2009 04:48 PM
94z28chick
Jul 14, 2006 12:39 AM
