94 Camaro Missfires, and No Power
So I got my 94 Camaro about a 2 years ago and it had a blown motor. So we replaced it and it ran fine for about a year, like it was perfect, it had nothing wrong with it but it had a abs inop light but I wasn't worried about it. Just recently it was having some coolant problems, a small power steering leak and a small transmission leak. so the number 1 priority for it was the coolant, so i went to the parts store for a temp sensor and when i came back my hood was open after a biblical storm came and it started to misfire.
I looked on some forums and I found some solutions, but they ended not helping. I changed out the coil packs, ignition module, spark plugs and wires, i cleaned out the injectors 1 by 1, and none of that fixed it, still misses and no power at all. I'm getting a little tired of buying parts and dumping money into this car.
Thank You It finally works!!!!!!
Thanks that actually worked i started unplugging things and i unplugged an injector fuse nothing happed so i replaced it with a good one now its running like a champ. spent all that money and it was just a 50 cent fuse. I am so relived and angry...... PWEWWWW I still cant believe i was running 3 cylinders on one side
