93 z28 rear wheel speed sensor
There are no rear wheel speed sensors for the 93 models, and as far as I know, traction control was not offered in 1993. For ABS there is a reluctor wheel attached to the differential carrier inside the differential housing. The sensor is located on top of the differential housing.
Thanks Pete. Do you have any other suggestions at why my abs inop light comes on at 10mph and stays on? Is it worth "cleaning" the sensor you described? I'm at a loss, I've checked all my ground wires and all my tail lights seem to work. Thoughts????? Thanks for your help.....
maybe next time
02-12-2012 01:55 PM
