93 z28 700r4/4L60 No Second Gear?
Old Aug 27, 2010 | 10:56 AM
belcherman's Avatar
The funny thing is the car drives great. It is just no second gear and the pushed up 1 position stuff. I didn't get it fixed yet because I think way back years ago they said to fix a trans on a camaro was over 2,000. This was because it is hard to get to and all this other stuff.
anyone else have to replace a trans on a camaro?
Old Aug 27, 2010 | 12:44 PM
trans is not that hard to change. https://camaroforums.com/forum/93-02-general-41/changing-4th-gen-auto-transmission-52327/
by the way a 93 has the 700r4/4l60, the 94 has the 4l60e. different transmissions. you both need to adjust your shift cable.
http://shbox.com/trans/A4_trans_linkage.html
the tv cable has to be set right. as tight as you can get it and still be able to get thottle to wot. is your speedo working? vss also has a part in the trans shifting.
Socom
Dec 6, 2010 09:56 PM
62rampsidekid
82-92 V6 Tech
Jun 26, 2010 04:01 PM
zlek131
Dec 28, 2008 03:41 PM
robmnrd
Jun 17, 2008 09:02 AM
