93 camaro 3.4L build
Old Nov 10, 2013 | 03:20 AM
Derek Tackett's Avatar
Default 93 camaro 3.4L build
Hey guys I have a question...how can i really get better top end in my 3.4L camaro...any ideas thanks
Old Nov 10, 2013 | 11:14 AM
You can, but it is not really worth all the work. Heads and intake from an engine used in front drive cars will help. You are stuck with the rear drive block because of how the blocks mount. And you are stuck with using a flat tappet cam because of how the lubricating system is configured on the rear drive blocks. You could also go to force induction, but the block won't like it if you go too high in boost. A better flowing exhaust and cold air intake will help some, but it won't make the car into a hot rod.
Old Nov 10, 2013 | 09:51 PM
hmm, would a LT1 swap be harder than fixin it up or easier
Old Nov 10, 2013 | 10:48 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Have a look at both threads in my signature, and then you decide
Old Nov 16, 2013 | 11:37 AM
v8 swap dont seem to bad..other than changing every bit of wiring but not bad...
Old Nov 16, 2013 | 02:36 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Well I changed all of my wiring since my donor car was a 1997, and my car is originally a 93. It wasnt very hard to do, it just took patience to swap everything over. Just mark all of your connectors and it will go back together quick.
Old Nov 21, 2013 | 01:16 AM
ewhen u built the v6..did it give u better performance or bout same
Old Nov 22, 2013 | 11:56 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
It was better than my old worn out 220k mile motor for sure, but I never really pushed it. The hardest I ran it was with a 50 shot and it ran 15s lol, so the v8 swap has better bang for my buck.
marks69ss
Apr 6, 2014 09:23 AM
CamaroJoe68
May 23, 2013 11:20 PM
JDMGreg
Jul 4, 2012 12:05 AM
CamaroKid1981
Dec 15, 2009 07:50 PM
American Muscle 100
Sep 15, 2006 07:55 PM
