918 springs worth it?
Old Feb 18, 2008 | 04:33 PM
deltav's Avatar
Default 918 springs worth it?
Hello, this is the scenario:
The engine is on the final stages of being done (with a cam) and the heads are already assembled with the 26915 springs. I bought the 26918 springs a few days ago, before I knew the heads were done. So should I get the 918 springs installed even though I'll get charged for it, or should I send the 918 springs back and exchange them (plus cash) for pro mag 1.6rr?
Old Feb 19, 2008 | 09:21 PM
JD1969's Avatar
Default RE: 918 springs worth it?
what are your cam specs?
Old Feb 21, 2008 | 12:18 AM
deltav's Avatar
212/218duration & 488/495 lift with stock 1.5 rockers. It's a small cam for dd and I never had a cam, but perfect time to put it in, during a rebuild.
Old Feb 22, 2008 | 09:20 AM
JD1969's Avatar
I run the 918 springs on a 231/232 598 lift cam. You should be fine with the 915's. As for the RR's I would call Comps tech line and ask them if the 915's will work.
Old Feb 22, 2008 | 11:15 AM
SpecterGT260's Avatar
Ninja Administrator
the 1.6's will change your lift.lift is proportional to the lever arm (rr) pushing down on it.(.495/1.5)*1.6= .528 lift. with 1.6RR this will be your accelerated lift.
the 915s will handle that just fine.
I have to ask though, why such a small cam. ur right around the stock cam's lift
Old Feb 22, 2008 | 10:20 PM
deltav's Avatar
I got that cam because the car is a dd, and wanted the slightest lope if any. I wish I could go bigger and get that lopey sound but, I don't want to be hassled by cops. I now know there's other cams but I was short on time and searched too late for them.
Krusher RS
May 23, 2013 11:51 AM
Challenged86
Aug 12, 2009 11:51 PM
350rs
Jun 26, 2006 01:19 AM
350rs
Jun 19, 2006 07:31 PM
