4l60e main seal leak - pull now or wait?
Old Jul 26, 2016 | 08:00 PM
grasshopper645's Avatar
Default 4l60e main seal leak - pull now or wait?
Basically as the title says. The leak is dripping off the bell housing quite significantly. with approx 100kmiles on it, should I pull it now and fix the leak, or just keep the level where it should be and go until it finally gives up.
It shifts fine currently, but is a bit harsh shifting in 2nd and 3rd. Dont want to go through all that work to fix the leak and then have to pull the trans again if its significantly warn.
Old Jul 27, 2016 | 11:29 AM
Everett#2390's Avatar
It's only going to get worse.
Fix now, or fix it later.
Old Jul 27, 2016 | 11:36 AM
2ToeRacing's Avatar
If it works correctly then you should fix it before it burns up. After it burns up it could take out expensive hard parts. Right now its a soft overhaul so...........
Corvette_Mike
LS Series Tech
Sep 20, 2014 10:53 AM
keaboi
Jun 18, 2011 12:41 AM
typeomang
Nov 21, 2009 08:37 AM
sewerrat
Aug 14, 2005 05:10 AM
