3.73 gear issue
Old Jun 17, 2007 | 12:59 AM
v8chvyguy's Avatar
Default 3.73 gear issue
I'm want to know how many of you 4th gen owners changed from the 3.23's to 3.73's in your 7.5 inch 10 bolts? Out of that, how many of you had a bad coast howl when you testdrove after the swap? I work in a drivetrain shop and rebuild diff's for a living. What I am running into is a rash of noisey 3.73 gear swaps. All in cars which had 3.21-3.23's and went to 3.73's. on both 2 cut and 5 cut gears. The setups were perfect and patterened out right. but, on the testdrive, the first time you let off the throttle it howls. There are three seperate cars, An 06 stang GT, an 06 Roush, and most recently a LS1 T/A. These were the only cars I regeared, the rest were Jeeps or Trucks, some of which got 3.73's without incident. I have only gotten the noise out of these three cars. The only common denomiator is the gear ratio's, automatics, and aluminum driveshafts. Aluminum shafts do amplify drivline noise, but, there was very, very little howlbefore the swap on the T/A and one stang had 5k on the clock and the other was about 7k, both were quiet before. The GT got its orig. 3.21's put back in and was quiet. Chew on this and maybe let me know if this might be a common issue.
Old Jun 17, 2007 | 10:17 AM
RS.Camaro.SS's Avatar
Default RE: 3.73 gear issue
thats not good news to hear, i was thinking about 3.73s i really want to hear if ppl have this problem..
3.4putter
Jan 28, 2012 07:35 PM
Bballard16
Mar 29, 2011 10:51 AM
l3loodred
Oct 22, 2009 10:00 AM
johnw
Sep 28, 2009 10:41 AM
dzroc
Sep 17, 2007 01:10 AM
