2nd gear slip on a auto tranny?
Old Jun 23, 2010 | 06:39 PM
auto's Avatar
Default 2nd gear slip on a auto tranny?
well opened up the Z on a straight earlier and when i floored it the squealed when going into second, i thought it only happens with stick shifts?
Old Jun 23, 2010 | 07:01 PM
What squealed, the trans? Did you feel it slip, like the car didn't lunge at all when shifting?
It wasn't the tires, or maybe even the serpentine belt you heard, was it?
Old Jun 23, 2010 | 09:32 PM
auto's Avatar
hmm, well when i floord it it gained speed, then i felt the shift and for that same second i heard from the back tires a squeal....... yeah a little lunge
i noticed too the headlights are aimed wayy off, where do i loosen to adjust the pitch for the headlamps?
Old Jun 25, 2010 | 02:23 PM
auto's Avatar
well here it is guys, back in black
Old Jun 25, 2010 | 02:36 PM
Looks nice! Did you figure out your "slipping" problem?
Do the NY cops bother you for having white-out on the front license plate?
Old Jun 25, 2010 | 02:42 PM
auto's Avatar
nope didnt find out the slipping problem, just going to take things as they come slowly. haha no, they dont give me trouble since they only see the back of the car
Old Jun 26, 2010 | 06:44 AM
maudyZ28's Avatar
wow, looking good dude. Did it have a full spray, looks well clean, much more than mine.
think the slipping is just the tires not the auto box, if it was the box you'd feel it disengage 1st then take ages to go into 2nd then there would be a wait before it put the power down, you'd notice it totally different from before.
Old Jun 26, 2010 | 09:29 AM
i would go with what 69 mentioned,,, a common problem is the serpentine belt slipping at high rpm shifts.
Old Jun 26, 2010 | 07:52 PM
If the car has been sitting and it has a much harder shift into 2nd gear then it did before you could have a stuck 1-2 accumilator. Drive is nice and easy. Does it still grab going to second harder then it used to?
Old Jun 27, 2010 | 12:50 AM
auto's Avatar
thanks guys, only the front was painted maudy i didnt get a chance to punch it again since that day gorn but id say yes comparing it to when i first got the car to now, it seems a little less out of control (slower), tomarrow i`ll give the belts a feeling up and give the throttle body a clean out.
do you think belt condish is a good idea or that`ll make it more slippery?
Hilchey02Z28
Jul 4, 2015 02:28 PM
lazybchbum
Sep 20, 2011 07:12 PM
Jamer
Dec 2, 2010 10:18 PM
mpd228
May 11, 2009 09:52 PM
