2000 V6 3800 fuel pump not turning on.. can't figure it out!!
Old Jun 28, 2016 | 05:22 AM
adamvindiola.av@gmail.com's Avatar
Thumbs down 2000 V6 3800 fuel pump not turning on.. can't figure it out!!
Help!
My fuel pump won't come on. No priming. Nothing.
It was running. Had the hood up because it has been running rough(due to the MAF sensor and bank one catalyst low efficiency or something) and then I touched a sensor says *sensor, pressure* on it. Then the car shut off and will not start. I ran a hard wire to the fuel pump itself and it turned on. Then hard wired the relay prong (upper left and lower right) and it turned on.... now I have no clue what it might be... please any help would be greatly appreciated
Old Jun 28, 2016 | 11:22 AM
do you have a aftermarket thieft alarm? can you post a picture of the sensor you touched. could be the connection or a wire is bad and when you touched it it moved and connection failed.
Old Jun 28, 2016 | 11:21 PM
I got it started. I don't have a scan tool so I couldn't just reset it. So I disconnected the battery entirely. Left it like that for a bit then I turned the key and the pump started to prime! I was so happy that I jumped up and down. Haha thank you though!
Old Jun 29, 2016 | 12:59 AM
that also clears the codes. vats could be acting up, have you had a security light come on or blink? weird that it shut off
charchri4
Apr 14, 2015 06:41 PM
86CamaroOwner
82-92 V6 Tech
Aug 14, 2011 11:36 PM
Toymachine
Feb 23, 2010 01:52 PM
Marine0401
Jul 1, 2005 12:00 PM
Darkslide123
Feb 20, 2005 03:56 AM
